HD4980 or GTX 460
IronRuler
I can get a GTX 460 1GB for 55 more bucks than I can a 4890. Which one should I opt for?
Problem is that I'm leaning towards an AMD setup because my brother has an MSI 790FX-GD70 he is selling to me for cheap. Therefore I won't be able to SLI which I plan on doing a couple months down the road. Unless I re-sell the 790FX for a nvidia chipset.
There is supposedly a hack to enable SLI on non Nvidia motherboards. Might want to Goolge it and see if it can be done on the board you're going to be using. If so, you have a real simple choice to make.
