HD4850 or 8800GT?
relic
[H]ard|DCer of the Month - August 2007
I have both cards and only 1 slot free (until I can put another box together in about two weeks), which one should it be?
8800GT is less $$ and more/same ppd depending on the WU.
I have both sitting here....which one should I install?
8800GT, ~4,500 PpD, Numbers
HD4850, ~3,500 PpD, Numbers
I think the 8800GT will do a little more PpD than the HD4850, if you get a good overclock on its shaders.
Luck .............. :D
Since you're going to fire up both within a couple weeks, I'd go for the GT.
You've been out the top 20 W-A-A-Y too long. :p
I like ATI, but RIGHT NOW the nvidia client holds an edge ...
Take the warning for what it is
I have 4 x 4850 & 1 x 4870 ..
Have you ever know EA to buy something that was not woth it?
(Been a while since I did the third-person things .. time to bring it back)
