HD485 uncomfortable
Eagle156
I've had them for about 2 weeks now and they are really uncomfortable after almost 20 minutes or so...
I've stretched them out on a pillow for many many hours and they still put way too much pressure on my head. If I adjust them to fit my ears correctly then the phones put pressure on my jaw which isn't a good feeling. They also really heat my ears up. After about an hour of wearing them my ears get all red from how hot they get. They sound good, but honestly the cheap $20 BB headset that sets ontop of my ears is more comfortable, even though it sounds horrible. I don't have a big head or anything so I don't know wtf to think. Does anyone else have this problem with these headphones? Is there any way to improve the comfort of these things?
Pics of your head, and ears, both with and without them on will help us think of solutions.
You should not use a pillow. If they are really snug try making them wider than you wanted to.
So why not have it stratle your pc case?
I'm stretching them out on the horizontal (long) side of the pillow, which is way wider than my head. The problem is that after 30 minutes on my head they are back to their normal skull cracking vise snugness.
