HD Water block recommendations?
kipling100
Can someone recommend to me a good hard drive water block?
How restrictive are these things usually? I want to build a pretty inexpensive loop using a D-TEK dB-1. I want to cool just my cpu and maybe a couple hard drives (no GPU or chipsets).
Thanks in advance,
Dennis
My own advice : Skip the HD blocks. Not worth the block cost and hassle.
I have a new in the box Koolance HD-55-L06 HHD Hyda-pak That I don’t think I can use it. All of the other tubing I’m using is 3/8 id. The Koolance device is ¼ id. Bummer.
Buy a low RPM fan instead. If you are trying for a cheap loop skip the HDD blocks.
I agree with the previous posters. WC the HDD's is not necessary and if you plan on going with any parts worth the cost, skip koolance. you want copper.
