I just built a new system and I've been testing out my Raid 1 array.
I'm running an Adaptec 1420SA controller and two WD2500SD.
I have been running tests to determine which driver combination performed the best. The Sequential Read graph used to be consistant.
Now after cleaning up all the cables I'm getting erratic graphs like this:
I was reading that due to improperly shielded SATA cables you shouldn't tie wrap cables together. I had only tie wrapped individial cables, not seperate drive cables together, but I removed all the tie wraps to be safe.
I ran WD diagnostics, no problems showed up. Any idea what could be causing these erratic results? Is this anything I should be concerned with?
