Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I can't say I've ever heard of it crashing. If you're overclocking, I'd check it with Memtest and Prime95 and bump it down a few steps and see if that helps. If you're not, check temps inside your case and other things that could cause stability problems - power supply voltage with a multimeter.
