HD not being detected.. sometimes
DontShoot
For some reason my HD isnt being detected during boot up. If I reboot it over and over, it'll eventually show up and everything is fine and dandy.. but when I shut the computer off and then turn it back on the HD once again isn't detected unless I reboot it over and over again. I tried swapping cables but it didn't work.
This HD was able to be detected just fine before I decided to switch cases with a newer one I bought.. so I have no idea what could be causing this. Did I screw it up during the switch?
The mobo I'm using is an Asus A7V 266-C and the HD I have is a Western Digital 40gb.
A Western Digital...
Is it on a chain by itself?
If so, remove the jumper instead of jumpering it to master.
Its on the Primary IDE channel as a master. Most of the time it isn't seen unless I reboot it a lot.
So another device is on the chain?
Try removing that device, and then removing the jumper from the drive.
Not all things play well togethor :)
Ok, if pulling the jumper does nothing then it's worth a try putting it on the second IDE channel (as the only IDE device in the whole machine).
If that doesn't work, I'd try it in another machine.
If it didn't work in another machine, I'd definitely be wondering about the drive.
If it did work in another machine, I'd be thinking power supply or motherboard.
O yeah, and does the drive always spin up even when it's not detected?
I have had probs with the 2mb cache version of that drive... went thru 4 of them in 3 months -
ok things to try... switch the power cable to a different one. Make sure that power cable is not shared by another hard/cd drive. Make sure all cabling for the power connects seat properly and have good connection in the molex connectors...
Check ALL power connects (as a weak connect to the board may cause issues)
Check your power supply. If you have had it for a long time ( 3 years or more) you may want to look for an upgrade... if it is under 300 watts upgrade ...
download WD's utilities and see if that gives you some answers.
Perhaps a corrupt bios (UNLIKELY) but worth a try - do a clear of it -
1) Try reconnecting the cable to the drive. Have you tried a different cable?
2) If nothing else works, there might also be a setting in the bios that adjusts if and how long (in seconds) the bios waits while it's detecting IDE devices. If that is at zero, try putting a one or two instead.
