Hd making a Tic, tic, tic, tic sound every second
Kryogen
My hd was sometimes making a weird noise last week (well I though so), and it went away. (So I backed up all my data, being parano).
Since yesterday, my comp is making a tic, tic, tic, tic, tic, sound every second. I think this comes from the hd, and I've heard some time ago that this could be the reading head resetting to the default position for an X reason?
What do you guys think about that? Is my hd dying on me? Should I get a new hd before this one crashes? Wait? Opinion? It's a 120 gig western digital HD, probably 1-2 years old.
(comp is working superfine though, no apparent hd problem)
It's probably dying. It's safe to do a drive test on it though. You should back up all your files ASAP though.
-J.
Western digital datalifeguard diagnostics program :
Fails the SMART drive test.
Multizone error rate is 200 instead of 51 (average rate of write retries) (or the opposite, whatever, fails that thing)
So um the drive is pretty getting fucked and I should RMA it I guess. Should I ????
The problem is that I cannot RMA before I get a new drive.... um.
Drive test = programs that are included on WD's CD tests hard drives.
Yep, it's dying. If you hear clicking during the first few seconds and it stops and it all goes smooth, it is okay. But not if it keeps going continuously. Back it up and RMA.
I'm sorry I don't understand that?
-J.
Most drive companies will do an "Advanced replacement" where they take your credit card number, and ship the drive out. When you get the drive, you have about 5 days to turn around and ship your defective one to them in the box the new one showed up in. The cc number is their protection in case you decide to try and stiff them and keep both drives. They will charge your cc for the new drive if it's not received within their specified period of time. Best way to do an RMA IMO, I wish most hardware could be done like that....although it's really up the mfr to decide that.
OCZ does that with Power supplies (well, they cross-ship...which is ALMOST as good).
Oh, that's nice then. So I won't have to go without my HD for a long time.
So I backup, zero the drive, and send back.
Good ;) I'll ask for rma. It's definitely dying...
If it is 1-2 years old then there's probably a pretty good chance it only has a 1 year warranty, in which case you are SOL. I just went through the same thing last week with a WD 200 gig. I started getting a bunch of 0x58s and 0x40s and that was it. At one point knoppix wouldn't even recognize the drive, but fortunately I was able to jimmy with it enough to recover a good amount of data. Pisses me off that it isn't under warranty, though.
what i don't understand is how they know that you shipped...
Couldn't you theoritically just ship your psu after u recieve it?
I think the way it works is you get the RMA # from them, then ship your PSU out, then call them back in regards to your RMA and give them the tracking #, then they ship the new one out before recieving the old one.
