HD Drive repair / data recovery
Dr.Khron
I had a SCSI hard drive fail on me.
Its an Atlas IV 73GB U160 SCSI drive.
The head always made a funny clicking sound, but I had found reviews online claiming that that was normal.
It worked fine for about 6 months, and then WinXP suddenly went into CHKDSK while booting, and monkeyed with the drive for a while. Now the SCSI adaptor wont recognize it from its own BIOS.
The drive spins up just fine, but then it just clicks nonstop, like the head got stuck.
A few questions:
Is there any chance this is repairable, or do I have to use a data recovery service which will pull the platters out?
What does drive repairs or recovery service cost?
Can anyone recomend a shop to me? Maybe one run by someone who frequents these boards?
-Dr.K
just check your phone book for local data recov. providors get some quotes. good luck i hate it when my drives crash
If it's not responding to probes or start unit requests it will have to be pulled apart.
When you start looking around for recovery services, you'll have a grab them ankles moment. It can run anywhere from $400-$4000 with no guarantees. Check with Quaxtor about the warranty policy if it's been professionally recovered - some mfgs will still honor the warranty if the place that did the job follows certain guidelines. That can save you at least the replacement cost on the unit, which is welcome after you pay for recovery.
