HD component video output to Y'PbPr ??
venm11
Video cards these days often have that 7-pin DIN output, s-video plus a few pins. I believe this is for component HDTV output, right? Is this universally true, such as on my laptop and/or geforce 7xxx?
If so:
1) Do they output RGB only, or can they do Y'PbPr? (most TVs seem to desire this)
2) Can they output 1080i ?
3) What's the deal with RGBHV ? Is this in any way useful or relevant?
I'm trying to find a better way to drive a friend's HD crt-rp TV than s-video.
thanks, fellers
The 7 pin laptop video out connector often only supports composite/s-video and digital audio out via a breakout box or cable.
On desktop cards the 7 pin connector on most cards made in the last couple of years does support HDTV out. Component video out is YPbPr and all cards with that output that i've seen support up to 1080i.
RGBHV should be regular VGA out, possibly referring to a specific type of VGA/BNC cable. http://pinouts.ws/db15-vga-pinout.html You might see BNC cables on some monitors that break out the VGA cable to R, G, B, H and V signals. I have an old 21" CRT with BNC inputs and the benefit is a very clean analog signal. The negative is that it doesn't support DDC to query the monitor's modes through that input. Some projectors also use BNC inputs.
Allright... this makes sense..
So my friend's TV has RCA inputs, although one set does have 2 extra RCA sockets for HV. I've only found RGBHV breakout cables with BNC, and only RGB with RCA. It will work acceptably with just RGB?
It also looks from the labelling on the TV that the components accept either RGB or Y'PbPr, is that possible? Can the input section detect which color space (?) is being used?
thanks again
