HD Cables for Xbox (1)
Robizzle01
Not talking about the 360 here, i'm talking about the original xbox.
I've had an old 27" TV forever, just bought a Westinghouse 37" W1 yesterday and it should be here today! I use my xbox primarily for XBMC but also do play a few games on it when the mood strikes me (few hours a week.) The Westy is going to be used most of the time for my HDCP but (legally obtained of course) downloads will be watched through XBMC. My question, should I bother buying the HD cables for the xbox or is it not going to make a noticable difference? I think they are something like $20 at best buy and I may go over there when I get off work today (need to pick up the new Guster CD.)
I checked around google some and couldn't find anyone that said the HD cables were either worth it or not. I did, however, read about some offbrand (non-M$) cables that rendered some games unplayable -- i'll stay away from those and I doubt Best Buy caries them anyways.
Here's the deal: If you're going to hook up the Xbox to your Westinghouse and use XBMC, the HD component cables are critical. At the absolute least, you'll be able to run your modded UI using the 1080i output and get a significantly better-looking experience. Depending on how the scaler of the Westinghouse is, you'll also be able to choose between 480p, 720p and 1080i output for all your videos, too. It's even a better deal for Xbox games because scaling from 480p to your panel resolution of 1920x1080 will look better than scaling from 480i (via S-video or composite).
While the Xbox isn't an all-HD experience like the 360, I've found the difference between S-video 480i and component 480p (my wimpy HDTV is a 27" CRT with probably at most 800x600 true resolution) to be like night and day.
QFT, I don't do XBMC but just the difference playing Halo 2 in 480p as opposed to 480i is great. It's not as great as playing it in 720p on the Xbox 360, but it's still great.
i suggest getting the Mad Catz Component cables... they sell for $15 and allow you to hook up an xbox and a ps2 at the same time... i have a set on my HDTV for when i feel like moving my xbox/ps2 around to a different room
The component cables make a -HUGE- difference in quality for all consoles, even at 480i its significantly better than composite/svideo. Moving to 480p is also a big quality increase for flat panel TVs as they don't have to de-interlace the 480i signal. As well you can run XBMC at 720p or 1080i which while not really having an impact on the video playback makes the interface much nicer.
ok, possibly stupid question. All the hd component cables I can find seem to be 5 wires. I figure that HD component requires 3 for video and then a left and right audio cable whereas original component is just 1 video and a left and right audio cable. Is this correct?
I'm looking at the user manual for my Westinghouse 37" (since I wont see my TV until tomarrow) and I just want to make sure i'm reading this right. On page 7 (page 9 in the PDF) of the pdf it shows the YPbPr hookups labeled as #11 and #12 and then #13 and #14 are YPbPr Audio Hookups. The descriptions almost make me think that all four connections are independent of eachother. However, common sense tells me that #11 and #13 pair up to provide both video and audio when I turn the TV to YPbPr Input #1. I just wanted to make sure this is the case before I buy the cables.
I tried to find the Mad Catz cables, illig, but had no luck. Not even the official Mad Catz website has them listed. All links I found to it on forums and other websites were broken and redirected to the main page. I'm not too concerned about having the port for a ps2 though, since I don't own a PS2. I think i'll just get this. Although not on ebay, I bet I can find it bricks and mortor somewhere.
Also, on an unrelated note. It says that DVI #1 supports 1080p while DVI #2 only goes up to 1080i. Whats up with that, doesn't the tv just have a switcher inside that picks which cable it wants to let through -- why should the secondary be any worse than the other input? Not a big deal in my case but still interesting.
Composite video, also referred to as A/V has one Yellow video connector and thje usual 2 Red/White audio connectors for stereo.
Component video is comprised of 3 cables for video (plugs colored red,green,blue usually) and the usual 2 Red/White audio connections. Yeah, the component video/audio inputs are paired up as 11/13 and 12/14.
Why the TV supports 1080i/p on different inputs is likely because it doesn't use an internal switch between the inputs but rather they're going through different parts of a chip/different chips. Likely VGA/DVI1 go through a chip/section separate from Component/DVI2.
THIS is the cable everyone is referring to, the local EB games and Walmarts around here seem to carry it.
