HD Audio header in the way
JacobC1983
so -- haven't gone sli in a long time. Just got my two GTX 980s and the PCI express slot (of two choices) on my EVGA Z77 FTW mobo is right in line with the damn HD audio header. I can't get the damn GPU in there. I can move the GPU up, but wanted some space between the cards for air and it just plain looks better with them separated a PCI slot or two.
What are people doing to get around this? Just not plugging it in?
Do all people with tri sli just not have front audio jacks?
I bet this has been asked many a time before --- thanks for the help!!
Pretty much. I had to give up my front panel audio and access to two USB2 headers to install my PhysX card in the last PCI-E slot. I just use a 3.5mm extension for my mic, and I already have an external powered 7-port USB hub to make up for the 2 lost ports on the front of the case.
I should add, this only applies with *most* cards that have a rather full-bodied shroud, i.e. almost every cooler out there. The only reliable way to ameliorate this is to either remove the shroud (if possible), or to go the custom loop route and install a waterblock, which will reduce the card's thickness to just one slot.
That sucks -- is there really no right angle adapter that will fix this? I haven't been able to find one so far.
