So I've encountered a strange issue...
My Diamond HD 7970 begins to artifact while overclocked in 3DMark Vantage/11, but then this artifacting carries over into other games. If I DO NOT run 3DMark tests, and run at the same oc'ed clock speeds, the same games no longer artifact (Skyrim, Half-Life 2, etc.). The artifacting ONLY occurs after I attempt either one of the two 3DMark benchmarks.
Even more strange, Battlefield 3 seems immune to this issue. Regardless of whether I run the benchmark(s) or not, BF3 never artifacts at the oc'ed speeds.
My temps are fine and totally within reason (I know another user had a Diamond card that ran hot). The only way to get rid of the artifacting from the affected games is to reboot.
On a final note, I've noticed that while loading the 3DMark test(s) a small black bar flashes at the bottom of the screen; this is always indicative of impending artifacts.
I am running the drivers from AMD's website.
