HD 6950 g card AMD
EGDestro
Hello all
i have a small problem i have a 6950 HD card when i got the card in the box i received an adapter from dVI to VGA so i can connect my display to it
now i have received the exact same monitor and its also VGA
i know that i cannot connect 2 monitors via the DVI as the one is a single way display and the other one is a dual channel signa l display
so i wanted to ask what can i do in order to connect the second monitor that is VGA i have located a few adaptors on amazon but i am not sure if they will work
http://www.amazon.co.uk/StarTech-Di...1_5?s=computers&ie=UTF8&qid=1335916468&sr=1-5
http://www.amazon.co.uk/Dell-BizLin...1_9?s=computers&ie=UTF8&qid=1335905173&sr=1-9
and a few more can any one tell me if the ones above this will work or not all i want to do is have 2 display thats all extended display nothing more can any one helpe me plzzzzzzzzz
i would like to get a product from UK so if you have any sort of links etc Please let me know again i do not want eyefinity' or any thing like this i just want to run 2 VGA monitors on 1 PC extended desktop thats all :(
just to avoid any confusion as i see some people have sent me msg and yeah
both of the monitors have VGA only
bump can any one help me plzzzzz i really want to get this sorted out as soon as possible
If your card has two DVI ports, you should be able to just use a pair of these:
http://www.amazon.co.uk/Cabling4Les...1_1?s=computers&ie=UTF8&qid=1336011292&sr=1-1
I'm assuming that your monitors came with VGA cables, so you just plug the cable into the adapter and the adapter into the DVI port.
Then again, I'm not sure what a single way display is versus a dual channel signal display. So, if you can't use two DVI ports (for reasons that I don't understand), I don't see why the combo that you linked would not work:
http://www.ebuyer.com/130561-xenta-dvi-i-single-link-to-vga-cable-black-2m-plex-058
and
http://www.ebuyer.com/281988-starte...-active-adapter-dvi-adapter-dual-link-dp2dvis
^^Assuming that is DVI to HDMI and your card has an HDMI port.
Which 6950? It doesn't help saying you have a new 6950, because one of my new 6950 cards has two DVI connectors and one HDMI, while a different card has one DVI and two display ports.
