hd 6870 reference design card
pimp_ffish
hi guys, do you now any difference between hd 6870 reference design card and the others brands hd 6870?!!!
i now the hd 6870 reference design it cheaper and i really like the design it pure.
Thanks very much.
Usually non-reference cards are the ones with cheap components and even crappier cooling.
I would stick to reference models (at least with ATi cards).
Posted via Mobile Device
the 6870, reference.
the 6850 toxic is more expensive and slower. Even if you over-clock it the stock 6870 will prolly beat it.
