HD 5570?
KoSMoKeNNy
Im looking for a decent low profile card to slap in a Dell Slimline Ive got laying around, and came across this: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161324
Cant find any reviews on it, just news blurbs saying its supposed to be out tomorrow. Anyone know what the deal with this thing is, i.e. where it would stack up against a 4650 or a 9600gt and what kind of power its gonna draw?
looks like its a 5770 with ddr3 ram if the specs are right. looks tiny though. Im sure the specs are wrong since it claims it has 800 SP's.
I would assume it it would have more then 80 SP's and less then 400 the 5670 has, maybe 160 or something. 800 for the size of Heatsink wouldnt work.
EDIT
found this on fud
According to the leaked slides, the HD 5570 card features 40nm GPU with 627M transistors and 400 Stream processors. It has 8 ROPs, 20 texture units, 650MHz core clock and uses DDR3 memory clocked at 900MHz (1.8GHz) paired up with a 128-bit memory interface.
there ya go, its going to be a 5670 but with lower clocks and ddr3 ram (not ddr5). draw is 42.7w and idle is under 9.7w
