First review found of the HD 4770
http://en.expreview.com/2009/04/24/first-review-of-radeon-hd-4770-99-monster.htm
This decent cooler will not be used for the Radeon HD 4770, as the above is nothing more than an image for AMD’s publicity compaign.
Rumored TDP is 80 watts, but it's not going to be a worthy upgrade from your 8800GT, definitely more of a sideways upgade, unless that's been giving you stability problems (the 8800GT uses more power than the HD4770).
Lol...still a dual slot cooler though with a stranger looking fan.
i am curious how you guys manage to kill graphic card i owned many gc but none had died on me
Actually, if I want to run 8xAA, this is the advantage since the ati cards do not take much of a performance hit. Also, if the 4770 retails for $99, probably they will be available for $20 less shortly after launch.
Well, my 2600XT died, it's this or a 4830. What would YOU get? Yes I'm on a budget.
The HD4770 is showing up in google's shopping searcher now http://www.google.com/products?q=HD4770. Looks like the card will make a release tomorrow. I want to get one tomorrow, but I need one that blows air out the back not in the case -.-.
I am very interested in this card and have actually been waiting for it for at least a month. Even so I am still waffling. I will be upgrading from a 7900GS KO so whatever I get will be a pretty big step up but have 2 concerns about this 4770. First, I have heard some pretty negative opinions about ATI drivers and second, no matter how much research I do, I can't seem to get a good feel for how this 4770 will compare with its nvidia counterpart (say the GTS 250?) interms of real world power consumption and heat output.
Could any of you guys make an educated guess at how it might compare, in terms of power consumption and heat output, with the nearest nvidia competition? The 4770 will force the GTS 250 down in price I would think, correct?
There are 4 of them listed on Newegg;
http://www.newegg.com/Product/Produ...0048 106792627 1067947628&name=Radeon HD 4770
I want one that blows air out the back personally.
You can get that nice double slot cooler from XFX for 99.99 dollars plus shipping @ mwave. http://www.mwave.com/mwave/viewspec_v2.asp?scriteria=3005196
That looks like the one to get right now.
I am running 2 of the ugly types in my RIG in Xfire and they work great.
I think the XFX model may not be the best option for tight PCI Xfire mother boards.
Looking forward to some good reviews of the XFX model. I hope Xfire works well for it.
I just got my XFX 4770 with the "Premium Cooler" I'm loving the card. I get about the same performance as my 8800 GTS 512 (was looking to replace it because I switched the computer into a smaller case). I'll try posting some overclocking and temps later tonight.
