HCSD card reader Question!
LeftSide
I was looking for an internal High Capacity SD Card reader. Will any card reader work with HCSD? I know my t-mobile mda won't read them, but my camera will.
Or if you know of a good internal memory card reader that works with High Capacity SD cards let me know
thanks,
Brad
If you buy one of the retail 4GB SDHC cards from SanDisk, it comes with a MicroMate USB SDHC card reader at "no additional charge" (though the 4GB SDHC cards normally retail between $70-$100). SanDisk also has the MobileMate SD Plus card reader for about $15-$20 retail. There are other SDHC card readers available, but the ones that I've mentioned are commonly found in B&M stores.
In terms of internal SDHC card readers, I was only able to find the Atech Flash PRO-Gear XM-28U card reader.
To answer your other question, not every card reader has the ability to read SDHC cards. Most products released this year can use them, and some products gain the ability to read them with a firmware upgrade, but I don't have the complete list as to which ones work/don't work.
