servergeek
- Jul 9, 2014
Hi All,
I am looking for some advice on recommended approach for my home VDI infrastructure as I am somewhat new to Virtualization. The conundrum I am facing is do I go the HBA DAS route or Team multiple NICs. I dont have any expertise with this stuff so treat me as a noob, no hard feelings.
Network Infrastructure:
Cisco Switch: 3550, 48 Ports 10/100 switch
Netgear Switch: GSM7324, 24 Ports 10/1000 Switch
Cisco Router: 2821
Upgrade on the radar: The only thing I am looking to change here is consolidating both switches to Cisco 4948 Gigabit Switch
Server Infrastructure:
Supermicro 24Bay File Server:
OS: Windows Server 2012 R2
Storage: Close to 20TB of storage running in non-raid format
Chassis : Supermicro 846TQ-R900B 4U 24 Bay Redundant 900-watt Power Supplies
Board: Supermicro H8DME-2 Dual Opteron Motherboard with 32GB of RAM and Dual NIC
Raid Controller: 3 x AOC-SAT2-MV8 8 Port Software RAID Controller
Processor: 2 x AMD Opteron 2374HE 2.2Ghz Quad Core CPU
Switch backplane or server out for 6Gbs HDD support. Another 24 or 36 Bay if I go the server route
20-24 Hitachi 2TB HDD or 4 SSD drives if I only purchase 20 HDD
1 or 2 Quad port NIC or HBA route
HP Dl585 G6
Detail Machine Spec: http://www8.hp.com/h20195/v2/GetDocument.aspx?docname=c04286599
Role: Hyper-V server running 11 Windows virtual machines
Memory: 64GB of RAM
Processor: 4 AMD Opteron 2.8GHz, Six-Core Processors
HDD: 8X 300GB SAS Drives, 2 HDD for OS mirrored, 1 HDD VM , 5 HDD in Raid 5 mode for VMs
NIC: 2 Quad port NIC, 2 NIC teamed for Servers, 2 NIC teamed for Clients, 1 NIC for external VPN IP addresses and 1 NIC for Internal VPN IP addresses
Upgrade on the radar: HBA
HPDL385 G6
Detail Machine Spec: http://www8.hp.com/h20195/v2/GetDocument.aspx?docname=c04286596
OS: ESX 5.5
Role: VMware server to be used for Linux and Unix virtual machines
Memory: 64GB of RAM
Processor: 2 AMD Opteron 2.3GHz, Six-Core Processors
HDD: 3X 146GB SAS Drives, 2 HDD for OS mirrored, 1 HDD for VM
NIC: 4 embedded NIC
Add additional SAS drives
1 or 2 Quad NIC or HBA
Thanks,
Servergeek
Cisco Router: 2821
HP Dl585 G6
Memory: 64GB of RAM
HPDL385 G6
OS: ESX 5.5
Memory: 64GB of RAM
NIC: 4 embedded NIC
Thanks,
Servergeek
