Hey, I recently fitted a NV5 silencer to my new 6800GT. When i installed it all seemed to be good, the temps were a great improvement over the stock cooler and there was almost no noise anymore. I load up Splinter Cell Chaos Theory and I get artifacts, not bad but little blue dots on some textures. I exit and load up rthdribl to check load temps. 51c load, much better than stock and I notice no artifacts. I took the card out and i notice not all the ram modules are touching the cooler (using thermal pads that came with it). This is the revision 2 of the silencer so the base completely flat. Hmm, just for interests sake i take it all apart and remove the thermal pads for the ram to see how much gap there is. There is no way i could fill that gap with Arctic silver. So i put it all back together and clock back the ram to 900mhz instead of 1000mhz. That solves the issue. Not happy at this point. What should i do? Chaos Theory is the only game it does this in too.
I tried putting the stock cooler back on and it does the same thing. The problem is i didn't have this game installed before i put on the silencer so i don't know if it was doing the same thing with the stock cooler. I was looking at the Zalman copper cooler that comes with seperate ram sinks, has anyone used one and what were your temps like?
Thanks in advance
Shadow27
Thanks in advance
Shadow27
