Whitebread
- Jan 28, 2002
I just recieved a brand new Linksys WRT54GL and I'm trying to properly set up a wireless LAN. I want to enable WPA encryption with a shared key and select MAC filtering to only let a few wireless machine access the nework. When I go into the encryption menu, I do the following.
I select WPA personal
TKIP encryption
then I ad a key in hex
leave the default 3600 seconds
I select WPA-PSK and TKIP encryption and then I add the key twice as required. Once this happens the computer disconnects, then reconnects to the wireless network. The problem is that, while I can access the internet and use trillian, etc, the network is listed as disconnected under Network conections and in the sys tray. I don't wnat this, how do I fix it?
Secondly. enabling MAC address filtering and selecting "allow" or "permit" or whatever it was kicked my laptop off the network and would not let it reconnect, eventhough I added its MAC address (confirmed via the computer name I choose) to the filter list. What gives? And after doing that, I can no longer access the router's menu. I think I will have to do a hard reset, which I didn't wnat to do! I type 192.168.1.1 and the page just keeps loading with no end.
TKIP encryption
