having trouble with an IDE card
Billiam411
Ok heres the issue:
my old computer that i use as a server recently had its ide bus die on itself (POS) it'll boot to a cd and install windows and such, but it wont boot to a harddrive no matter which channel it is in. The drives show up in the bios as normal, but it just wont boot to them. If IDE HDD is the only choice in the boot menu, itll just have a flashing _ in the top left corner. if its not, itll proceed down the order. I have tried reformatting the main drive (and wiping it with 0s) as well as a second known working drive. I posted this earlier and came to the conclusion that the bus is dead, or something like that, and that i'll get a pci ide card.
I get a card, pop it in, and boot to the xp cd. i press F6 to load additional scsi drivers, and insert the card's floppy. it recognizes the floppy and installs the driver, but then once it starts the setup it claims it cannot find any hard drive installed.
If i go into the card's config, it recognizes the drive just fine.
Any help?, or is my whole motherboard a gonner?
PS it will not boot to any hard drive installed on the ide card either, at least i dont think so, these things are complicated to configure :p
Try setting it to boot from SCSI first. With older motherboards you have to do this to boot from any add on card.
If the IDE channels are going out, I wouldn't put much faith in the board...
As for getting it to recognize the drives, Lothar is probably right about stting the BIOS to boot to SCSI first because that will force the BIOS to go out to the PCI slots and look for cards. And if you can remove the IDE HDD from the boot list completely, that would be even better. Also, there may be a setting in the BIOS that allows you to tell it not to boot from the IDE HDD, (other than/in place of removing the drive from the boot list).
thanks guys but i already found another solution. i had a similar dell that was a PIII so i just switched out motherboards :eek: half way through i realize that dell uses proprietary motherboard mountings between their own product lines (even though the cases are exact same (dimension 4100 and xps b866) so i had to do some 'modifying' but it all works now
