yallknowho
- Dec 26, 2005
I just can't get my wireless print server to work right. Heres what I have ...
Linksys WRT54G Wireless-G Router
D-Link DP-G321 Wireless-G Print Server
Originally, I thought it would be great to use the wireless feature of the print server to catch a signal from my Linksys so I can keep my printers on the other side of my office without running cables. Turns out, its not supposed to work that way. I was still supposed to hardline an ethernet cable into the D-Link and then hook up the printers. Then the idea is to use the D-Link to broadcast the wireless signal. At any rate, after 3 hours on the phone with a couple of Indians who insisted I restart my computer 7 times, I was able to manually set the IP of the D-Link to be on the same network as the Linksys and it actually worked. It was buggy, but I was able to print to both printers.
Problem .... it lasted for about a day then the printers would be offline. I'd have to reinstall the printers on each machine to get them back up. Finally, I drilled a fucking hole in my floor, ran an ethernet cable from my Linksys to my D-Link through my basement and it worked.
Problem ... it lasted for about a day then the printers would be offline. So now I have to keep deleting and reinstalling the printers pretty much anytime I need to print something.
First of all ... this particular WRT54G, the version I have is probably the worst router ever made. Buggy as shit. But I don't think that the problem is due to the known issues with the router. I have a feeling it's some setting or something more simple I'm overlooking.
I have the Linksys set to DHCP, every machine and the D-Link pull IPs automatically. But the D-Link is manually set at 192.168.1.10 .... as are the TCP/IP ports I created for each printer. It's high enough to never cause a conflict considering I only have two desktops and two notebooks currently. And th IP addresses start at 192.168.1.1 ... and while I admittedly am a borderline retard with networking, it seems like there has to be some sort of time out going on. Is it in the Linksys? D-Link? Because on I'm XP Home and not Pro?
Any clues?
Any clues?
