Ive been running my new 146 CABGE 0536VPAW opteron on default past few days and now ive finally had some time to play around with it, but things aren't looking great.. anyways, my goal right now is to hit 2.7ghz stable..
and i thought i achieved that, but the minute i opened up IE/IM programs, my computer restarted.. and this was AFTER I did a full 32m super pi test with prime95 small ftt running in the background WITHOUT any problems..take a look at this ss: http://img479.imageshack.us/my.php?image=opteron2700mhz3ow.jpg
why didnt it go unstable during the strenuous testing? thats my question.. right now whenever i try to do 2.7ghz again, it either resets on desktop, resets on startup of applications, resets in games or benches, bsods, or simply doesnt post.. ive run out of ideas to try :|.. and i based all my settings on OldGuy's post (he has same mobo/ram as me).. this is what i used:
Genie BIOS Settings:
CPU Overclock in MHz = 270
Hammer Fid Control = X10
AGP Overclock in MHz = 68
LDT/FSB Frequency Ratio = 3X
AMD K8 Cool and Quiet = Disable
CPU VID Control = 1.525v
CPU Voltage Adjusting = +0.2v (undervolts so bios shows ~1.6v)
Chipset Voltage Control = 1.85v
Memory Voltage Control = 2.8v (overvolts and shows ~2.88V)
AGP Voltage Control = 1.6v
DRAM Configuration:
Memory Hole for PCI MMIO = Disable
Max Memory Overclock (MHz) = Auto (200)
1T/2T Memory Timing = 2T
Cas# Latency (Tcl) = 2.5
Ras# to Cas# Delay (Trcd) = 4
Min Ras# Active Time (Tras) = 7
Row Precharge time (Trp) = 3
Write Recovery Time (Twr) = 2
Ras#-to-Ras# Delay (trrd) = 4
Row Refresh Time (Trfc) = 13
Row Cycle Time (Trc) = 11
Write-to-Read Delay Twtr) = 2
Read-to-Write Delay (Trwt) = 2
Refresh Rate (Tref) = Auto
Write Cas Latency (Twcl) = 1
Max Asynchronous Latency = 8ns
Read Preamble = 6.0ns
Dynamic Idle Cycle Limit = 256
DDR Output Driving = Weak Drive
DDR DQ Drive Strength = 50% Reduction
ECC Function = Disable
Here's some information about my RAM... it's supposedly brainpower (has the silver pins in the back), it's TCCD and it is currently being run on the orange slots.. i also did 10 loops of test #5 from MEMTEST and no errors have been reported for up to 280Mhz 2.5-4-3-7 @ 2.7V (actual is 2.79V since it overvolts).. so the above settings SHOULD work.. the SS i showed earlier of super pi being successful is with the ram run on a divider, 5:6 i believe...ALSO, 1T does not work with my board, so i can do 2T only, its just too buggy with 1T.. anyways, ive tried uppin voltages for vcore, i went up as much as 1.525v + 0.3v = 1.825v which is suppose to be ~1.7v but even that didnt work..
So the question is, why cant I get 2.7Ghz!?
DRAM Configuration:
