For a long time, bittorent sucked on my computer, it was so slow I didn't even bother using it. Is the same happening to you?
If so try this
Try what it sais on this page, once you are done, go to your bottorrent program's settings, and set your port for incoming connections to 6881 - 6889
It helps alot.
If so try this
It helps alot.
