Ok, I have solved the problem.
Scanning PCI Bus Mechanism #2 is caused by this one thing.
PCI Devices, namely Audio devices. In my case because I have no PCI cards so it's the OnBoard Audio (Soundstorm). All I had to do for this past year was disable it in the BIOS. OMFG. How annoying is that.
Surely I am not the only one using OnBoard sound on this board who has tried to boot from a cd rom atleast once in the last year, but it would seem so. Or at least very few as a google search provided.
I've traded up my SB Live! which I bought in 1999 for an even worse substitue in NVidia Soundstorm ObBoard audio.
How do I make this information publicly available to help out other people with the same issues?
- Original Post -
Thanks for replying in advance.
I currently have 4x HDD's. 3x PATA, 1x SATA.
Disk0 has an old copy of Windows XP on it, which I cannot delete format in XP.
Disk1 was an extended partition with no O/S ever installed.
Disk2 has my current installation of XP Pro
Disk3 is a New SATA I have, which has no effect on the other drives.
If I unplug ANY of my PATA drives I get the following error -
'Cannot start windows because the following file is corruct or missing - <Windows Root>\System32\hall.dll' (Power connected to HDD, but set to ignore in BIOS)
'Disk Boot Failure, Insert System Disk And Press Any Key' (No Power to HDD, set to ingore in BIOS)
I will explain why this is a problem.
My XP Pro CD, will not boot from the CD-ROM. Why, I dont know. How do I get this thing to boot (it's all enabled to boot in the BIOS, I know this because my Win98SE CD boots).
My FDD is out of action, so I can't use it.
My only other option was to use my Win98SE cd to load cd-rom device drives then switch over to the XP cd and install it from there, in theory this should work but I get this exact problem when trying to do so -
Scanning PCI Bus Mechanism #2 However the remedie suggested does not work for me as I use no PCI devices. Any suggestions.
These issues go hand in hand, and I really need one to do the other, so as I can get a new install of XP on my system.
- Original Post -
