Hello
i just finished a new build and everything was working fine for a few days. I had over clocked my cpu to 4.5 and was stable and starting to oc my video card. It started having issue where my computer would reboot and it said i had a failed over clocking. I keep tweaking and testing and everything was ok for a while, but it was still rebooting once in a while, and then i noticed i only had 12gb of ram when i should have 16 installed. i reinstalled my ram and it showed 16 agin, but it keep losing the one of the sticks. So i ran mentest86 and it failed. i checked my ram status in my bios and it said c1 was abnormal, so i installed in d1 and ran the memtest it did 3 passes with no errors with all 4 stick installed . So i booted to my os ran prime95 for 3 hours and was fine then i just started surfing the web and the computer froze up and i rebooted and i went into bios and check the ram again and d1 was now abnormal, so i found the possible bad ram and removed all the ram and left the bad ram in d1, and i had to reseat it to show up again. I ran memtest again and it failed, and i can't booting into my system without reseating the one ram stick. it goes from working to abrnomal over an over.
aslo note i removed the overclock and went with optimized default settings, the only thing changed was the ram speed set 2400, ram timing set 10,12,12,31,2, ram voltage set to1.65
any advice would be helpful. I've been testing and trying to figure out this issue for 2 days. Thank you
System spec
rampage iv black edition
i7 4930k
G.SKILL Trident X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) F3-2400C10Q-16GTX
samsung 840 250 x2 in raid 0
samsung 840 250 x2
Hard drive 2tb
evga supernova 1500
evga gtx 780 ti classifed
System spec
i7 4930k
samsung 840 250 x2
Hard drive 2tb
evga supernova 1500
