ReptileMatt
- Mar 21, 2007
How are things?
I don't know how good some of you are with overclocking and stability but for some reason my PC is shutting off at random times. My temperatures seem extremely low so I'm not to sure what the problem may be. I'm thinking it could have been my overlock.
System Specs:
AMD x2 3600+ Brisbane
Abit KN9 Motherboard
Thermaltake TMG A1 HSF w/ Arctic Cooling
Corsair XMS PC6400 1GB DDR2 800
EVGA 7900GS KO (stock)
PSU: Thermaltake T2 470W 28Amps dual 12v.
About 5 case fans. Good cooling. Really good cooling.
2 IDE Hard Drives
2 ROM Drives
For some reason my PC has shutdown a few times in random applications. It shutdown once while I was playing a Day of Defeat:Source. It shut down a few times when I was opening up a few windows of CPU-Z and temperature program.
I have a screenshot for you all to look at: http://img87.imageshack.us/img87/7720/brisbanehelpbr0.jpg
PWM temperature is about 47 C.
You can see my CPU OC and settings. I am a newbie to these new AM2 sockets.
My motherboard has a lot of other settings such as DDR2 REF voltage, CPU VDDA voltage, HT voltage etc which I kept default. I'm not sure if I should be touching those or not.
Right now I put the system back on stock settings to see if it causes the same problems. Hopefully not!
Also some wierd things I've noticed: I unplugged my floppy drive because the light would never turn off. The power is still plugged but the 40pin cable is disconnected so the light does not turn on. When putting my PSU 24pin cable in...the clip didn't click. So i pushed it down so it did. Not sure if I should unplug and replug it. Computer is turning on ETC though.
Also...video card temps on idle is around 43 C. In applications (DOD:S) it's a little more...like mid 50 C's it seems.
Any adivce would be much appreciated.
I ran Memtest 86+. It detected my memory speeds at DDR500 I think. Don't know why...but it passed. I used Orthos for a while. No errors but system crashed once or twice with a hard shutdown while running...but I also was doing other stuff as well.
Thank you thank you. I will be checking back here A LOT! Sorry for the length.
System Specs:
2 IDE Hard Drives
2 ROM Drives
