having problems all of a sudden...
s.Lim
sup fellaz...
ive had my comp for about half a year...everything was running good...until recently...
i rebooted my comp and it wouldnt load up windows...just shows black screen where it would normally show the windows xp screen loading up...
i thought it was the power supply so i bought a new one and stuck it in...still seems to have the same problem...
apparently my system works when i only power up certain hardware...right now im only powering my dvd-r drive...
if i plug everything up including my other dvd-rom drive and floppy and fans...the system does the same thing where it wont boot up the operating system...
can anyone help?
ps i dont kno too much about comps
abit ic7-max3
p4 2.4 800fsb ht
512 ram
36gb hd
4x sony dvd-r
ati 9600 pro
dvd-rom drive
antec true550
i actually figured out that it only doesnt boot up when both my dvdrom drive and my dvd-r drive are powered...
is there some conflict with using one serial ata and the other type of connection?
and is there a way to fix it...
i was running this setup for a couple months and it was fine...
Ok so when both your serial ata drive and pata drive are connected, it doesnt boot. Does it: 1)not show anything, 2)go to bios, 3)get caught in windows? Are they on the same channle? Is the sata drive going through a pci card or directly to the motherboard, or is it converted using a pata to sata converer?
ya i can still get into bios...it goes blank after all the dos prompts disappear...
instead it shows nothing where the "Windows XP" logo is suppose to be displayed with the loading bar...
the screen just stays black...
i dont think it gets caught in windows cuz the operating system never seems to load up...just blackness...
i dont know if both my drives are on the same channel...
the sata drive goes directly to my motherboard and not thru a converter...
your only solution is to reinstall windows, and see if it roects the problem. b4 u do this, take someone elses harddrive with windows off it, and just connect it and see if itll boot. u dont have to change anything in bios as long as ide1 is your harddrive. using another harddrive already with windows, or any os in this case, is the best way to check wat is wrong. test this, if it boots of the other hardrive, its just a corrupt windows, wichu can fix in like 30 minutes by just a clean format. let us know =P
ya...originally...i thought the problem was either a virus or power supply...so i formatted and reinstalled windows...
but that did not fix the problem...
any other suggestions?
Have you tested the memory?
I haven't dealt with SATA yet, but I had a thought. Do you need to install special drivers to use SATA drives. Something along the lines of installing raid drivers?
ok so lemmy get this straight.. right now you have 2 dvd drives or something around there if you unplug both of the dvd drives does your computer work yes/no?
if you plug just one does your computer work yes/no
answer these questions
if you answer yes to any of these might just be your IDE cable messed up
i think the memory is fine...
the comp does work if i unplug both drives...
the comp does work if i just plug either one of the drives...whether i use a sata or pata...
i tried pluggin both drives with a pata...and it seems to boot up like before...the drive seems slower than the sata tho...
i want to try and run both drives if the sata cable works...but my cable isnt long enough to reach both...so i mite try and buy a new one...
if anyone has suggestions...will be appreciated
