Having problem with hdmi connection
I tried to plug my tv into my pc using hdmi connection but the hdmi on my AB350 Pro4 does not work. So i bought a usb hub with a hdmi connection on it but it uses usb c to connect to pc which is when i found out the usb c connection on MB also does not work. Is there something in the bois i need to enable to get these two things to work? All the other connections on MB work just not these two.
Denpepe
What CPU are you using? did you try hooking the TV up to the graphics card or the motherboard connector?
Using a ryzen 5 1600 so it's not that. Just have an old geforce gt 710. Sometimes it works plugging it into my graphics card but it makes the task bar freeze and i have to restart the computer to get it back to normal.
Denpepe
Well your CPU does not have integrated graphics so you need to use a discrete GPU
