When I am setting the mem divider at 166Mhz
I am able to go till 256 HTT(FSB)(reaches my mem limit 209.5Mhz),
But When I set the mem divider at 133 Mhz I am not able to go past 237/239 HTT.
My PCIe and PCI bus are not locked, checked in clockgen.
HT link set to 3x. CPU multi is 9x
Can anybody tell me what is the reason for this?
If I set the DRAM frequency to auto it is set to 166 MHz by default so no use .
But If I boot using mem divider 166Mhz and then using A64Tweaker change it to 133 Mhz, I am able to go till 280 HTT in clockgen.
Another question
what is the ideal temp at full load for this processor If I am using stock cooling?
At 280HTT Coretemp shows 60'C tempwhere as ASUS Probe shows 55'C
Which is correct?
Another question
Which is correct?
