- Jul 24, 2008
This a duplicate post that I made in the Operating System forum, maybe this is a drive question?
Hopefully some one can help me out here.
One of my HDD's on my media server has been been misbehaving recently and not showing up in Windows after coming unplugged and being plugged into a different port.
I tried first to find it using Disc Management and it doesn't even appear, so I hooked it up on another system and it shows up in Disc Management, but it doesn't show the partition, only unallocated space.
I've dealt with this before with other drives, so I used a piece of software called Find&Mount to make sure that my data was still there and that the drive didn't take a shit.
Data shows up fine (movies) and is able to be watched.
I hooked it back up to my server, bring up CMD and try to use mountvol to find the unmountable drive. I find it easily and input this to try to manually mount it:
mountvol E: \\?\Volume{c2158fd9-91b3-11e1-a23a-806e6f6e6963}\
It comes back with "directory is not empty", so I try another drive letter and this time it mounts but with nothing on it.
So I tried E: again and the same "directory is not empty" again.
My question is, what other command should I try to use to mount it? Should I try to use /R to get rid of the directory's or will that screw up my data? /P gets rid of the mount points, but there is none to get rid of. Or should I try another method altogether?
