Hey everyone, I seem to be having an issue installing windows from my USB drive and I can't figure out what the problem is...
I plug in the USB with windows installation and It says its loading files than it starts up windows where you get the 4 balls of color form to make the logo, after it is made then the screen goes black, all thats on the screen is the mouse pointer and that is it. I've swapped out video cards (didn't think that was the problem since video was showing) and still I get the same problem, I put windows on the flash drive all over again and still I have the same problem... I used the flash drive a day earlier to install windows on my other PC and it worked so I'm trying to figure out what I should do at this point. It's a brand new hard drive to so that shouldn't be the problem
