KaptainBlaZzed
- Jan 12, 2005
I just put a 3.4EE in my asus p4p800 and it almost works correct.
i can run SuperPi just fine but when i run PCMARK04 it tells me that half of the
first two tests fail. One part works and the other does not so i can't get a score.
also when i restart my comp my monitors shut off but the computer continues to run, the only way to get it back is doing a hard shutdown. It alos does the same thing when i enter the bios and then exit the monitous go black and the computer continues to run.
any help would be great.
my system is as listed bellow but with a 3.4ee @ 4.0
with a vcore of 1.775v and FSB 235
at 1.8 volts i can't get into windows.
3.2 Ghz P4 Prescott @ 3.81
2 X WD Raptor 36Gb RAID 0
BFG Tech 6800GT @ (431/1110)
4 x CorsairXMS 256mb pc4000 (3-4-4-8)
ASUS P4P800E Deluxe
Koolance Exos ( CPU & GPU )
Enermax 600 watt noisetaker v2.0
Klipsch 5.1 ProMedia
2 x Eizo 15in LCD
ASUS P4P800E Deluxe
2 x Eizo 15in LCD
