Having a problem with new computer - Help greatly appreciated
Hisx1nc
Ok, I just put together my first computer, I believe it went well, computer boots to BIOS no problem. Sometimes I get a CPU is unworkable or has been changed CMOS error which is easily fixed by clearing CMOS. I get that error after I change things in BIOS it seems.
My major problem however is when I try to install Windows XP SP2. I got the copy from my college for free, so there could be something wrong with it. I downloaded the file as an ISO, and burned it to a CD-R. When I get to windows setup it always gets stuck at "Setup is loading files (Windows Executive)..." and it stays there. Any ideas? Is the copy of XP bad, or is it a problem with the computer? Any help/ideas would be greatly appreciated.
This is what is in my computer:
CPU: C2D e6750
MoBo: Abit IP35-E
RAM: OCZ 2GB
HDD: 320MB 7200rpm (seagate barracuda I believe)
GPU: EVGA 8800gts 320mb superclocked
Case: coolermaster centaurian
PSU: eXtreme power 550w
DVD-RW drive
My first guess would be a corrupt download... try re-downloading if you can.
No, I have not run mem-test yet, is that something that I can burn to a CD-R and don't need windows to run? If so, where can I find it?
Yes, it could definately be a corrupt download, hopefully not though, but I will re-download and re-burn it to find out. I doubt this is the case because the file has been up for a long time and if there was a problem with it I feel that they would have found out by now. I doubt I am the only one taking advantage of the free OS.
Google, download and burn Memtest+ to a CD and run it on each stick of RAM separately for at least 3 hours or 24 hours if you want to fully rule out the RAM. If a single error shows up, the stick of RAM is bad.
If no errors after at least a few passes, try different cables, different optical drives, different hard drives... whatever you have spare parts of that you can swap in and out. Its usually a hardware failure when the installation hangs. You can get a drive fitness test from hitachi and run that to test your hdd/cable.
Fixed the problem
memory was set to 1.8v
took 1.9-2.0v
changed it to 1.9v and it was golden
