Having a hard time getting Lucid Virtu going
Payne
I think I've tried about everything to make it work but I can't seem to make any progress.
Motherboard is z68ud4 rev 1 latest bios
gtx 560
i5 2500k (HD3000)
I've updated the hd3000 drivers from Intel's website and I've the latest nvidia drivers installed also.
I just can't get the damn virtu garbage to select the gtx560 for any programs in the application list. The monitor is hooked up with onboard video (hd3000) via HDMI output.on the motherboard.
In the bios i have selected onboard video as init display and onboard video to always on.
I'm lost. Any help is appreciated.
I did have it working at one point but I had to put the bios back to default due to me pushing the overclock a bit too much. i have since then put everything to optimized default in the BIOS. And since then I can't get this bloody thing to work.
Try plugging the monitor into the gtx560 card..... just as you said,, the lucid chip is absolute garbage.
Try plugging the monitor into the gtx560 card..... just as you said,, the virtu chip is absolute garbage.
thanks for your reply
I'ave tried plugging the monitor to the nvidia video card and the problem just reverses. I'm able to run applications via the nvidia card but if I want to use the intel quicksync with Media Espresso for example, it just doesn't see it as an acceleration option. I'm only able to use the Cuda engine.
That's still way better... i'd recommend just disabling the lucid chipset if you can,, the nvidia card should be plenty good enough.. i would actually disable the onboard video altogether, and disable the lucid chipset too and just use the nvidia card. the cuda engine hardware acceleration on the 560 should be way faster than the intel based acceleration anyways. Obviously the Media Espresso program does not support the intel acceleration fully. This is the main reason i will not buy a motherboard with an onboard video chipset or a cpu with a onboard video processor .. too many issues.
Which virtu are you using? Virtu, Mvp or universal? I'm using a z77 board with gtx460 with MVP and have no problem getting it to switch properly. I don't use the combined graphics "Performance" features and I don't encode anything on this system so I'm basically just using it for the power savings of onboard graphics. Even that's questionable since the discrete card is still running the whole time at low idle anyways.
the regular one...Green.
I have tried MVP also and that exhibits the same problems for me.
