Having a hard time choosing a mobo ...
rayearth
I getting ready to build my next box and am having a hard time selecting some components. I usually would research this over 2-3 months, but I cannot wait that long. My current core system:
Abit NF7-S mobo, AMD Barton @3200+, 1 GB DDR400, Maxtor 200 GB, ATI 9800NP
I'm looking to build this
Some Nforce4 mobo
AMD Athlon 64 4400+
Scythe Ninja HS
2 GB ram
WD 74 GB raptor primary + cheap but large secondary
Antec P180 case (waiting for all black edition)
Seasonic S12 500w ps
? pci-e video
Primary goals for system:
1) stabilty
2) quiet
3) mild-moderate OC on air
4) improved speed / responsiveness
I need a parallel port for my printer (it doesn't like USB). I have a PCI parallel port if the mobo does not have one, but rather not use it. I don't ever plan to do SLI (too much heat/noise).
I'm looking at the DFI lanparty UT nF4, Asus A8N, Abit AN8, and MSI Neo4, Gigabyte GA-K8NXP-SLI. I'm leaning toward the first three choices due to issues with the MSI on this forum. This will be the 6th system that I have built and tweaking the bios does not faze me. Any recommendations?
The Lanparty is very overclockable, but I have heard that it may be very picky about ram ...
The Asus is stable but not very overclockable ...
The Abit .... I have not heard much about.
<sigh> so hard to decide.
the DFI is very overclockable -- my lanparty ultra d overclocks much higher than my asus with the same cpu--but this was only a fact after a bios upgrade.
the ASUS can also overclock very good --it is just not a super overclocker like the DFI.
the DFI is not as pickey about ram as you have heard. my DFI ultra D overclocks to the sky with super crappy hynix -- if you set the memory dividers to match what the ram can do .
before the bios update the asus and the DFI overclocked about the same .
the only gripes about the DFI are it only has two pci slots and it has so many diffrent voltage tweeks and there is no safety factor in them . i have seen people kill their ram trying to tweek it . and i killed a crappy winchester 3000 trying to get it stable @ 2.7g-- how i killed it ? i accidently gave it too much vcore-- the DFI can overclock safe--but with the new bioses it is just too easy to get MHZ greedy and kill something. if you err to the side of caution the DFI will be a good pick.
the DFI also has that new layout-- --whatever-- might be a + or might be a -negative.
Pick Asus mobo if ur plannin to do a little of ocing on air with good stability.
Pick DFI if u want to oc like mad man on air with super stability on it.
I think u should go for Asus.
