Haven't seen this 7.65L cube case before...
It says right in the description that it's using a 120mm fan on the right side. The only way I see to fit an AIO in there is if no PCIe card is installed, and then you'd probably have to mod the top to mount the rad.
That shell certainly looks nice, but I could imagine this to be a real pain to work in.
Other than that, pretty much what Necere already said. You could try to place an AIO without the fan obove the GPU and leave sucking air through the rad to the GPU fans, but I think that would be a horrible idea :D
Everything else requires a good bit of modding.
I also like the name of the product: "MiniSYS Q197 Mini Qube HTPC Quiet Gaming Case mini ITX NAS Aluminum chassis". They just threw buzzwords in there, that thing is not optimised for quiet operation at all.
GPU is fine I guess, however it is not advisible to put a 60+W CPU in that thing :D
Maybe no GPU and just use a AMD FM2+ setup then you could use a AIO
