I am in the market for a new printer right now. My Kodak ESP7 printer that is just over a year old decided to stop feeding paper from the paper tray. Kodak won't help because the printer is out of warranty. I had so many problems with the Kodak that I definitely won't be going back that route, despite the very affordable ink.
I have been researching new printers to replace the one I have now. Essentially, I am in the market for an all-in-one printer. My wife is in school and she also works part time from home, so we need a printer that has copy, scan and fax capabilities. I have narrowed it down to what I think are two solid choices, but I would like to get thoughts from others [H] members.
1. Epson Artisan 810
2. HP Officejet Pro 8500 Premier
I am sort of leaning towards the Epson right now, because I discovered during my research that there is a continuous ink supply system (CISS) available for this printer. There may be one for the HP also, but I have not located it in limited searching. Ink is so expensive, which is why I went with the Kodak. Using a CISS with the Epson would most likely be even cheaper than buying ink for the Kodak though.
My questions are: has anyone used a CISS? Did it work well? Would you recommend a CISS? Any thoughts on where to buy a quality CISS? Finally, any thoughts on these two printers, or another one that you think I should consider instead?
