Any of you know where I could get the FTW bios??
http://uploading.com/files/8d9985m8/evgagtx295-coopftw-dentnu.rar/
I uploaded it there for you. I already flashed my card and am still running tests. Seems stable so far, of course this is going to depend on your card.
Some instructions should you or anyone else need it:
FYI, rename evgagtx295-coopftw1-dentnu.rom to ftw1.rom, and rename evgagtx295-coopftw2-dentnu.rom to ftw2.rom
The idea is just to shorten the file name, you can name them whatever you want...the 1 or 2 is important though as it'll help you identify which rom file corresponds to which gpu you are flashing.
Create a usb boot disk, and make sure to put nvflash, bios files, and cwsdpmi.exe files on it. Set motherboard to boot from usb stick...Then use these commands to save your stock bios files should something go wrong:
nvflash -b -i1 gpu1.rom
nvflash -b -i2 gpu2.rom
Once that's done, flash your gpus to the new bios using these commands:
nvflash -4 -5 -6 -i1 ftw1.rom
Once that's done....type
nvflash -4 -5 -6 -i2 ftw2.rom
It'll probably say something like vendor id is different, do you wish to proceed and force flash...just type 'Y' and enter.
Then you are done. Open gpu-z and you should see this:
