Have to clear CMOS to boot???
loki_racer
I've had the same rig for three years now.
ECS KA3 MVP
AM2 3800+
8GB ddr2 800
ATI 2900
OCZ GameXStream 700W
The motherboard has two PCIE x16 1.0 slots. Since I do more programming than gaming on my system and recently bought a third monitor, instead of buying a video card for the third monitor, I bought an ATI 5850.
I updated the motherboard to the latest BIOS. Swapped the 2900 for the 5850 and cleared the CMOS. It booted right up. After installing the new video drivers I rebooted and the PC never started back up. The fans are running, hdd spinning but no POST beep.
So I check that cards are seated, memory is in, etc. Nothing works. So I try clearing CMOS again and it boots right up.
I have contacted ECS tech support and they are painfully slow at responding via their ticket system. Nobody will answer their tech support line.
This was their response:
Code:
1. If you put the old card back in again, do you have to clear CMOS when you reboot everytime?
2. If the answer to the above question is no then there could very well be just a compatibility issue between
    the motherboard and the VGA card.
3. And if that is the case you need to test the motherboard with a slightly lower grade VGA card from
    the 5850.
How can this be a video card issue? The motherboard and video card work together. It's the BIOS not working in my eyes. Why would this card not work? PCIE x16 2.0 is supposed to be backwards compatible with 1.0 right?
Other things I have done. Replaced CMOS battery with new battery. Let battery out of board and CMOS clear jumper set for 8 hours.
Any other ideas? And yes, I know I need to upgrade motherboard, cpu and ram. It's on the list, but like I said, I work 10 times as much as I game now and just need to be able to boot my PC without having to clear cmos.
Have you tried another BIOS version? It sounds to me like there is a particular issue with this BIOS and the video card.
I have tried others. The board has TopHat BIOS so I tried that and two other versions of the BIOS. All give the same issue.
I would play around with the BIOS settings like RAM settings, CPU settings and boot settings.
Had an issue similar to this with a friends IP35 pro. It turned out to be a ram issue. Default bios ram voltage was 1.8v whereas the rams stock volts was 2.0v. Booted fine after a manual adjustment. Just my exp. Good luck!
similar issue myself , however did not have a the video card swap issue.
Board was bad, RMA'd it
I would still try the obvious, single ram, voltages etc, ya just never know
The BIOS works fine with old card, just not with new card. Have come to believe that card (PCIE x16 2.0) and board (PCIE x16 1.0) don't play nice. Extremely disappointed in ECS for not compling with PCIE standards or this wouldn't be an issue.
ECS tech support is horrible. I have contacted ECS, XFX, MSI and ASUS recently for various issues with relatives' computers. ECS is by far the worst tech support. I have called at least 20 times on various days and times and nobody answers. I will never buy ECS again. Only bought before because they were the first crossfire board to market with specs I wanted.
