Just that I want to buy a card rather then wait for the Mac card if it does not work. I never flashed a video card before, so I can probably figure out how to do it.
Where can i get the BIOS file? Will it boot initially and you flash it before loading the OS? What if it is not detected - does i tmean you cannot flash the BIOS?
Thanks.
you sure? if so then that would mean you can put any vid cards in a new intel mac, but i dont beleive it is that simple... i am sure Apple has something coded into the bios to look only for their hardware.. i would think, being apple and all.
I'm not sure that will work but I don't believe trying will cause any damage either. My main cause for concern is that in a mac pro there are no pcie power connectors so all the power must come from the motherboard. Since all the 8800gt cards I know of for standard pc's require a pcie power connector, I can only conclude that a standard motherboard does not supply ample power. I have dozens of mac pros around so if I have time tomorrow I can test one.
