Have a serious problem
Confederate
I have a buddy with a serious pc problem, I tried eveything to help but nothing , Now I am here trying to get help.
Heres a video in case you dont want to read description below
http://www.youtube.com/watch?v=x9Zn8DGyTdg
Ok well I brought my computer with me from NY to UT in the box the tower came in with all the packing so it was nice and snug and was inside didn't flop around or anything. I hooked it up and it worked flawlessly for a week. I finally got the internet hooked it up and went right to Call of duty to play... It played fine for a day or two but all of a sudden I booted it up and I got AVG needs to close, then ATI control needs to close, then Modizilla and so fourth. So Im thinking great I got a virus. I start to run different checks and in the middle of an AVG virus check or Spy bot the computer just reboots. Not a blue screen reboot but a black screen and BEEP.... the computer is already rebooting. Nothing on startup to say system shut down the wrong way do u want to run safe mode, just a normal windows screen. I then try and try and some times it would finish a virus scan and find nothing other times it would reboot half way through. So I never did find a virus. I wait a day and then the computer wont start up past bios. I gwent out and bought a new hard drive... same one I had seagate 500Gb and install a fresh copy of XP... Though it didn't do it right away, an hour into using it, it rebooted. So I take it to the geek squad for there opinion.. They keep it for a week and tell me that they couldnt figure it out but its most likely the mother board (orginal mother board was an MSI 45 platinum) so I then went out and bought a new mother board (ASUS P5Q-E). I boot up and wambo it does it again in no more than five minutes. Im at a lost so I figure I'll try cleaning the new hard drive off and reinstalling windows XP pro again.... I get half way through the install and it reboots and will not go any farther.... I NEED HELP
2 LITE-ON 20X DVD±R DVD Burners
Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500
Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM SATA 3.0Gb/s Hard Drive
Patriot Extreme Performance 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
Antec EA650 650W ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
SAPPHIRE 100247L Radeon HD 4870 512MB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
ASUS P5Q-E mother board
Does safe mode work?
Also, regarding the boot.ini issue: http://support.microsoft.com/kb/330184
Oddly, I got the "Invalid Boot.ini" on my recent Vista install when I switched from IDE mode to AHCI mode. Stupid automatic disabling of unused storage protocols :). Nothing worked to fix it and I had to reinstall anyway.
Good luck! Weird indeed.
Well at 6.3years on the board I will just assume you can properly install a heat sink and the symptoms don't really fit.
Do you have an old power supply you could test with? I have no reason to think the Antec isn't up to the task but it could be you got a bad one. Also never hurts to boot and run memtest. Always nice to know if it passes and also be great to see if you PC reboots while in memtest.
I think it sounds like a RAM issue to me, I experienced similar smyptoms when I don't put enough voltage and set the timing manually. Have you tried that? Maybe one of the sticks are bad.
