Ok I am doing a build and I finally give up trying to figure it out on my own. I can't narrow down the problem. Computer locks up sometimes after a minute sometimes after 5 +minutes.
Hardware
ASUS M2N AM2 NVIDIA nForce 430 MCP ATX AMD Motherboard {bought open box}
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131042
AMD Athlon 64 X2 4000+ Brisbane 2.1GHz 2 x 512KB L2 Cache Socket AM2 65W Dual-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103774
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memoryhttp://www.newegg.com/Product/Product.aspx?Item=N82E16820145590
{this is recommened memory for the MB}
Seagate 120GB HD SATA/Seagate 320GB Sata
COOLER MASTER eXtreme Power RP-600-PCAR
http://www.newegg.com/Product/Product.aspx?Item=N82E16817171013&Tpk=cooler+master+600
Antec 900 case
800Xl His
Samsung DVD burner
OK ive tried everything I can think of I have offically thrown in the towel. Computer starts up powers up fine. I can go into bios no problem but it the computer just locks up after a while. I have tried to install windows. I can get as far as the second step of installing windows but it locks up. I thought it was the memory I originally had bought PQI memory but sent it back because I thought that was the issue. I got the recommended memory for the MB and I can run a memory test with ubuntu {can't get that installed either} and it checks out fine untill the computer freezes. Ive updated the bios to the latest and greatest. I haven't adjusted really anything in bios, just boot devices. Ive tried a IDE hard drive, changed to a cd drive, different video card and the memory and different power supply's. Ive tried 1 stick of memory in every different slots. So I think I have it narrowed to MB or processor unless I have something in Bios conflicting that I am overlooking. If you have any ideas please let me know.
Hardware
Antec 900 case
800Xl His
Samsung DVD burner
