I am running STOCK 4770K with ASUS Z87 PRO, no OC.
NOCTUA NH D14 as a cooling options
Problem is my CPU is using around 1.24 voltage under normal load ( playing crisis 3) and Temps Rise around 73C. I heard these chips use much less voltage ? What gives, did I just get a poor chip which requires more volt to operate ?
When CPU is sitting IDLE the TEMP Drops to 42C and Volt drops to around 0.080 V.
By Default Core 0 is set to 39 ratio, Core 1 39, Core 2 38 & Core 3 37. I wonder why they all wont work to 39
