- Apr 12, 2003
Isn't this sort of what people were expecting? Haswell was targeting power use most aggressively I thought. Besides if it overclocks really well who cares.
Not from the attitudes I have seen from some people on here.
Haswell's claims to fame are supposed to be power usage and graphics, right? So that's good for mobile, even if it's less exciting for those desktop users who use discrete graphics instead of on-CPU graphics.
Haswell has a 10-15% bump in IPC over Ivy. Though the clock speeds haven't budged, the performance should still be an okay step up.
They said the same thing about Ivy Bridge. It ended up being more like a 5-9% bump.
The Ivy figures were regarding performance bump, not IPC bump. With the small jump in clock speed and the single-digit IPC increase, Ivy ended up being ~10-15% faster than Sandy. Haswell isn't getting a clock speed bump but rather the increase in performance is coming strictly from IPC gains.
It's too early to tell that Haswell will only be IPC improvements leading to its figures, much less if they figures hold true. I have yet to see a review where Ivy held a solid 10% in more than a couple tests w/o OC and when comparing SB OC to IVB OC I'd take Sandy.
It wasn't that it was bad, it was just misleading in its claim to be that big of an improvement over SB. The wikipedia article quotes 5-15% improvement clock for clock compared to SB and that just wasn't true. That's a pretty big gap, but for the same price you weren't really losing much.
