Well... here is what is going on and tested so far...
Seems the other day , he ran into the problem that his machine did not power on with the switch , and now only via the PSU switch. This will quickly power up the board and the devices ... but will not POST at all. No beeps , no nothing. Just fans running. Also New PSU has been gone through a 350watt and a 500watt PSU. Both New. Currently on a 350watt new antec.
So the PSU has been swapped with no luck there. Stripped down to just cpu/hsf/ 1 stick mem to see if it will at least post/beep .. nothing. CMOS reset ... nothing. I looked on the board and did not see any burnmarks or anything on caps/chips. I am starting to think the mobo is gone. Board's little led light is green when the psu is switched on.
Specs of it are asus a7n8x board , i believe 2500+ chipset , corsair xms ram (256 each / pair) 9500 card.
Any ideas???
Any ideas???
