Has anyone using immersive INC. Holo3D II?
Damn, I've never even heard of the Holo3D until I saw this thread. Looked around the net a little and this thing looks promising. Can't find any really detailed useage information on it though. How does it work? Appears to only have inputs. From what I've seen, it looks like people are inputing their standalone DVD players into it for processing, which doesn't make much sense.
Can it be used to decode video from your PCs onboard DVD player and output via say, a 7800GT into my big screen? I would rather like to maintain DVI output via. 7800GT.
It works just like what you said. Pure input and processing only.
The question is I also have immersive HD-AUX added Card......... One DVI-I input & one for output
look at the PIC
So let me get this straight, it's pretty much a Faroudja chip on a PCI card that can take in DVI and component and then upscales it to HD resolutions (it also upscales SD content from the Xcard) then you can pipe that out to your video card and then to your TV?
I've seen it before but never have I actually looked at it nor bothered to see what/how it works (mostly because of the price tag).
Nice, DVI daughter card. Makes me want it even more now. I see a lot of data cable inputs on the card, do any of them accept a direct DVD-ROM connection as an input? Or is it still required to use a standalone? Sorry to keep asking questions in your thread, but I'm very curious about this thing.
Thanks - Matt
IDversusEGO said:
what's the $$?
Digital Connection list it at $895.
Thanks - Matt
I believe you can do that with the Xcard, I know that the Xcard does direct to DVD connects and then I figure that since this is for upconverting SD content you'd connect the Xcard to the Holo3D.
Awesomeness, I definately need to do some more research on this thing. Daddy wants :D
Glad to see so much replies ^_^
Go on reaching how to get Digital input from X-Card
Direct cable connection between Holo3D II and X-Card is Ok
But I can't find the choose "X-Card" in input menu, each Rev. of Holo3D software differes a little, can I treat all digital input as SDI?
Does this card take in HD footage (1080i) through component? I want to input HD footage into my computer to archive.
