Jebus said:I am compiling it right now, if anyone has it already, I wouldn't mind hearing about it, good or bad.
vinnie said:Hey... you're still around. You've been in my sig for years, I thought you'd dissapeared
No, I've not tried it but I wait patiently for your review. I'm still trying to decide which windows manager I want and am open to suggestions.
Silent1 said:did you build this using garnome? I'm also currently building this using garnome and its gets stuck at nautilus-2.7.1 complaining about esound. I have it installed but it keeps saying
Package esound was not found in the pkg-config search path.
Perhaps you should add the directory containing `esound.pc'
to the PKG_CONFIG_PATH environment variable
No package 'esound' found
I'm running debian so i installed esound thru apt-get. I also tried to install it thru source but that also gave me wierd errors as well. Configure went thru perfectly but during make it gave me this,
esddsp.c: In function `open':
esddsp.c:172: error: `RTLD_NEXT' undeclared (first use in this function)
esddsp.c:172: error: (Each undeclared identifier is reported only once
esddsp.c:172: error: for each function it appears in.)
esddsp.c: In function `ioctl':
esddsp.c:373: error: `RTLD_NEXT' undeclared (first use in this function)
esddsp.c: In function `close':
esddsp.c:392: error: `RTLD_NEXT' undeclared (first use in this function)
make: *** [esddsp.lo] Error 1
Any help would be great, thanks.
zerogt86 said:wow gnome is looking good, havnt used it in a while. personally im still waiting for e17 though.
