Code:
Release Highlights:
* Updated driver to WHQL Certified driver for GeForce 6 series only
* Adds support for GeForce 6600 series GPUs (products supported)
* Added support for using HDTV over DVI connectors
* Added support for advanced DVI timing on all GeForce 6 series GPUs
* Updated Application Profiles allows users to associate color settings and store multiple profiles per application
* Added support to recognize and display monitor name in all control panels
* Supports 512 MB frame buffer GPUs
* Added supported for TV/HDTV setup in the nView Display Setup Wizard
* Updated Gridlines to for easier grid setup and management
* Microsoft® DirectX® 9.0c and OpenGL® 1.5 support
Support for 512MB frame buffer? Is this vaporware speak or is nVidia actually contemplating releasing a 512MB video card??
Also, I noticed that on my GT there are two check boxes on the actual PCB itself denoting whether or not it's a 256MB or a 512MB model.
Anyone know anything about this? Or has this already been discussed and I've missed the bandwagon?
